How do we setup the IC chart of accounts? Is it required to import the entire chart of accounts? Or we can import only the necessary accounts for outbound documents & inbound documents?
What are usually the chart of accounts setup for the IC?
No, but once you import the data, it’s simply easier to import ALL records than filtering them somehow…
?? This is a question to your accountants (and depends on whether the CoA’s are identical or different for each company)…
added: and don’t forget about IC Dimensions, too!
