I want to create new company and database as existing in Nav 2009 Sp1.
same as existing database and company.
Hi Kalyantupe,
You really need to put more information into your questions, if you like us to answer and not just guess… [;)]
Well if you need an entire new database, then just make a copy of the database in SQL (backup and restore).
But if you just need a new company in the existing database, then create it from the Classic client. If it needs to be a copy of an existing company, then the easiest way in NAV 2009 classic client was to create an NAV backup of the company. Then rename the one you backed up to the new name and restore the NAV backup.
