My input data is like: ABC DE 12 3456
I need to split char and numbers separately
value1 = ABC DE
value2 = 12 3456
even there will be a space also in splitted values
value1 = ABC DE
value2 = 12 3456
Try this…
msdn.microsoft.com/…/aa867746.aspx
i need to use this function inside ssrs report
Try the following expression for…
value1 = System.Text.RegularExpressions.Regex.Replace(Fields!Name.Value, “[0-9]”, “”)
value2 = System.Text.RegularExpressions.Regex.Replace(Fields!Name.Value, “[A-Z]”, “”)
Replace function is not working on ssrs…
Ur AX version.??
AX 2012 r2, VS2010
