Investigating why style sheets won’t work for some members of staff I have found the issue appears to be the above error. Users that have ‘super’ rights are still getting the above error when trying to perform certain tasks. I understand this is the software believing they do not have the appropriate rights but as they are set up as super users I don’t understand the issue. Is anyone able to give me some very simple and clear steps to check/resolve this? I am affectively set up the same as these users and I do not experience the issue.
When database is in “Single User” mode and more than 1 session is tried then following error occurs:
Microsoft Dynamics NAV Classic
The following ODBC error occurred:
Error: [Microsoft][ODBC SQL Server Driver]Database is invalid or cannot be accessed
State ID: HY024
OK
Resolution: Change the database access mode from “Single User” to “Multi user”, which can be done in three ways described earlier. Though the SQL query will change a little bit:
USE master
GO
EXEC sp_dboption ‘DatabaseName’, ‘single user’, ‘FALSE’; // Note that True has now become FALSE.
Thank you for your suggestions, I’ve managed to locate the user setting on the SQL Server Management - the database was already set to ‘multi user’ rather than ‘single’.
Hi, could you please tell me how to assign permissions? I’m not IT trained but have no back up for the system, so trying to muddle my way through - simple explanation please! Thank you.
Sounds like you are having either Kerboros and / or active directory issues with your system.
In File / Database / Open, then the advanced tab, change the net type to Named Pipes and see it that helps (thats assuming that named pipes are enable on your sql server)
The net type is best left to Default, but you may be able to change it to get it working while you sort out the root cause
Hi, I have accessed the SQL management system previously, could you detail how to assign permissions and I will see whether I can follow the instructions, unfortunately I do not have support available currently so that is not an option. Thank you.
Thank you for the link, I logged onto the server, onto SQL manager and went to security and logins, I didn’t see a list of users in that section that were indentifiable (e.g. windows logon names), however, to test I set all users list there to sysadmin permissions but this did not change anything for the user.
