i have scenario in which i want excess data using table id… So please tell me it is possible or not…
For Ex.
TableName TableName = “CustTable”;
While Select TableName
// code for my logic…
after compilation i will get these error
Table TableName doesn’t exist // because in AOT TableName table doesn’t exist in Table…
2nd scenario
DictTable dictTable;
dictTable = new DictTable(tableName2id(TableName));
while select tableId2name(dictTable.id())
in these case i will get syntax error
So,please tell me it is possible or not in these case to excess data; if possible then tell me reliable logic for that…
Common common;
DictField dictField = new DictField(tableNum(CustTable), fieldNum(CustTable, AccountNum));
dictTable = new DictTable(tableNum(CustTable));
common = dictTable.makeRecord();
while select common
where common.(dictField.id()) like “US*”
info(common.(dictField.id()));
thanks kranthi …it’s work but please tell me how we group by record
For Ex ;
in my case , i wan’t
while select Common group by common.(dictField.id())
I don’t think you can do that with in a select statement, but you can use the query frame work to do that.
Query query;
QueryBuildDataSource qbds;
QueryRun qr;
Common common;
DictField dictField = new DictField(tableNum(CustTable), fieldNum(CustTable, CustGroup));
query = new query();
qbds = query.addDataSource(dictTable.id());
qbds.addGroupByField(dictField.id());
qr = new QueryRun(query);
while (qr.next())
common = qr.get(dictTable.id());
