The number series management always does an increase of one. You cannot increase automatically by 10 with the standard code, as you have found out.
INCSTR is the function normally used to increase a string value with one. So if you want to do it in the same way, and with less possible changes, then you need to call INCSTR 10 times, instead of just one.
[:D]Hi Bittu,
Really Interesting Question / Requirement As Usually You Got Cu 396 Standard .
If you really want to implement that code then Lets See The Situations
Sort the Record By Find Last Get last Rec No then Add 10 comprises new No.
Testtable.RESET;
Testtable.SETCURRENTKEY(“No.”);
IF Testtable.FINDLAST THEN Begin
MESSAGE(’%1’,Testtable.“No.”);
“Next No.” := Testtable.“No.” + 10;
Exit(“Next No.”);
End;
Note: As You said It’s a Integer , So above Code works (Hope So…:)[;)])
If the No is Code Datatype You Have To compare All No’s For the Latest As 1000 < 9
(OR)
Use a table To Store Last No’s for Respective Tables As 308, 309
I never used but I believe this is something which may help you. In the No Series Management there’s a column as Increment by Look at the below screenshot and update it with 10 and then try please.
