I have to write a resource “.resx” file in X++. The requirement is to read labels from SysModelElementLabel table in AX 2012 and then write a resource file containing all the fetched labels. Then this resource file will then be used by an HTML5 application.
Does anyone know how to write .resx file in X++?
Anas.
.resx is based on XML, therefore you can generate it from X++ as any other XML, if you want. Nevertheless it may be easier in .NET, where you can even use ResXResourceWriter class.
I have written a job using the ResXResourceWriter class in .NET. You can see the screenshot below. I just want to ask you that am I heading in the right direction?
If it works (I believe so), your direction is good.
Just don’t forget to dispose the writer.
A simple solution for seemingly a complex probelm
Thanks Martin!
