How to write
report to copy all customers from one company to another company? please help me/… |
How to write
hi veera,
you need to be more specific then this dear, like do you want a report or form with a button?
in what structure do you want your output?
there is a properity called ‘copy’ which will copy a table record.
do you have 2 companies?
hi,
You have to create a report with one dataitem based on customer’s table. create a global variable based on sames table (named “Cutomer2”)
In the OnAfterGetRecord Trigger put code as:
Customer2.changecompany(Company2Name);
Customer2.init;
Customer2.transferfields(Customer);
Customer2.insert;
And that’s all.
Good luck
Hi Mr.rafaa,
if u dont mind can u explain it.it is asking about changecompany variable and Company2name.
I think that if you do not understand what b.rafaa writes, then you should not go into that operation…
I agree. If you just copied that code and expected it to work then you shouldn’t be doing this. Get in touch with your NAV Partner.
Create a report with a dataitem for table 18 “Customer”,
an input field for the new company name in the request form and a record variable Customer2 for the Customer table.
In the OnAfterGetRecord Trigger write :
Customer2.COPY(Customer);
Customer.CHANGECOMPANY(NewCompany);
IF NOT Customer2.INSERT(TRUE) THEN
Customer2.MODIFY(TRUE);
