Can anyone tell me, how i can insert the data from one table to another table using Maps.
Scenario: Lets say , table A which is having 1, 2 , 3, 4, 5 fields. and table B is also have the same fields which are in table A and 6, 7 also. here i want to insert the 1, 2 , 3, 4, 5 fields data from table A to table B using Maps.
please helpme out on this (if possible, with example)
I think he wants the Map object, not the Map_Class…
I don’t think you’re supposed to insert into maps like that because they don’t define database objects. I thought they were more for associating a field with multiple tables and viewing/accessing data.
To do what you’re talking about, which isn’t normal I don’t think…I’d think you’d need to overwrite the insert() method on the actual map, then literally do:
tableA.field1 = this.field1;
tableB.field6 = this.field6;
tableA.insert();
tableB.insert();
Here is an example of how to update/build your address with the address map…maybe this will get you started.
