i have created one method as shown below,
void FilterProductionOrder(str 20 _prodPoolDate,
str 10 _prodPoolId, boolean update = false)
Query query = new Query();
QueryBuildDataSource qbdsprodTable = query.addDataSource(tableNum(ProdTable));
QueryRun queryRun;
info("Date: " + _prodPoolDate + "PoolName: "+ _prodPoolId);
qbdsprodTable.addRange(fieldNum(ProdTable,SchedDate)).value(queryValue(_ProdPoolDate));
queryRun = new QueryRun(query);
startLengthyOperation();
while (queryRun.next())
prodTable = queryRun.getNo(1);
info (strFmt(“PoolId : %1 SchDate: %2”, prodTable.ProdPoolId,
prodTable.SchedDate));
ttsBegin;
prodTable.ProdPoolId = _prodPoolId;
ttscommit;
endLengthyOperation();
here i want to update Production Pool as i have written,
ttsBegin;
ttscommit;
MY AIM IS " while fetching record which has date mention in “_prodPoolDate”, that all should be assigned to Production pool mention in “_prodPoolId” "
Above code is executing without error. but not gives desired result.
Pls. replay as soon as possible.
Thank You in Advance.
Mehul Thacker
