shasha
#1
i have a form with some records from temporary table.i am opening a new form where i am giving some values.
and after clicking ok that values should update against the records(from temporary table) showing in the main form.
how can i update the records against records from temporary table.
Hi shashank,
In case your still want to update the data.
If your datasource of the temptable is called tmptable this is the code to do it.
TmpTable localTmpTable;
localTmpTable.setTmpData(tmpTable);
ttsbegin;
while select forupdate localTmpTable
localTmpTable.Field1 = “NewValue”;
localTmpTable.doUpdate();
ttscommit;
tmpTable.setTmpData(localTmpTable);
tmpTable_ds.executeQuery();
Hope it helps you.
