Do we have any books/articles/links that will help to understand and solve best practices errors according to their diagnostic Id.
I was having problems with following BP errors:
The property caption should be set to @format (BP:495) → I did set it to @ABC12 format but still the error persists.
TwC:The keyword forceliterls must not be used in the query expression(BP 831)
why is method bound to client when it has no client calls?(BP 650)
consider moving the method that runs on the client tier into a separate class as a static method to run the server tier (BP 630)
Label is changed on the control from Hours to Hours (path form\formname\Designs\DesignLists) (BP 165)
Thanks in advance for all your help
Shankar
