Pls tell me how to solve this issue…?
Thanks in advance…
Thanks in advance…
How do you define your path? Can you post your code snippet?
Since it is impossible to debug in citrix, Can u tell me how to solve this…?
This seems correct. I was able to export the report to local drive in the same way from Citrix. Can you tell me which report is this? Is this customized report? Standard option which AX provides to store reports to file allows saving to the local system. If this is some customization that you have performed, then it might be related to that.
Yes.It is customized report…
