how to show abreviated field value in C\Al
I have a field "Marital Status ". his type is an option
I have to create report and i want to show the status abreviated for example “M” in Place of “Married”
How can i do this please
To display the abbreviated form of the marital status in your report, you can use a feature called “Option Caption” in Business Central. Here’s how you can achieve this:
  1. Open the Object Designer in Business Central and locate the table where the “Marital Status” field is defined.
  2. Find the “Marital Status” field and click on it to open its properties.
  3. In the properties window, navigate to the “Option Captions” section.
  4. In the “Option Captions” section, you’ll see the different options available for the field. Assign the desired abbreviation (e.g., “M”) to the “Married” option.
  5. Save the changes to the field properties.
  6. Now, when you use this field in your report, it will display the abbreviated form (e.g., “M”) for the “Married” option.
By utilizing the “Option Caption” feature, you can customize the display value for specific options within an option field. This allows you to present the information in a more concise and user-friendly manner in your reports.
Please note that the steps provided above may vary slightly depending on your version of Business Central or the development environment you are using. It’s always recommended to consult the official documentation or reach out to a Business Central expert for specific guidance tailored to your environment.
