how to SETRANGE integer value?
hai all… how to setrange integer value?
like this PurchaseLine.SETRANGE(PurchaseLine.“Qty To Receive”,> 0);
→ it doesn’t work…
i want to filter the items that have qty to receive is greater than 0
thanx for the answer
Use SETFILTER
PurchaseLine.SETFILTER(PurchaseLine.“Qty To Receive”, ‘>0’);
wow !! it works !!!
thanx nuno !! :slight_smile:
The difference between SETFILTER and SETRANGE is that with FILTER the parameter is a filter string, and with RANGE the parameters are from and to values. Go into the C/SIDE reference guide (in the help menu) and search for the two, there are excellent explanations in there.
