how to set page editable after clicking action button
Hii
i have create a page header & line page, add a action released , when i click on released action button then page also set in not editable. how to set page not editable after clicking released action button. please give me some idea…
Thank You
Hello,
This should be very easy.
Create a boolean variable.
On the on action trigger put the variable:=false.
In the page properties put the variable name in the EDITABLE property.
best regards,
‘’ is not an option.
The existing options are:
No, Yes
when i set editable =variable then showing these error in nav 2016
Hello,
remove the “<” and “>”
best regards,
Hii
thanks for reply but i have also remove the “<” and “>”, showing again same error The existing options are:
No, Yes in NAV 2016
Did you add Boolean type variable with IncludeDataset property set to yes?
Yes , i have already Set boolean type variable with includeDataset Property set to yes but when i set variable in Editable property of page and pressing TAB . its showing an error ‘’ is not an option.
No, Yes
Hello,
I tried to add variable to page properties and it’s not working.
I think you have to set it on every field and part page in the editable property.
best regards,
yes, we can set on every field in the editable property,
thanks have a great day…
Glad I could help!
best regards,
