How to set Feild Filter (F7)
Hello Expert,
I have one query my customer want to set a filter like Feild Filter (F7), before posting the item journal in case of postive adjutment in item journal there is feild which is called approved , once approved tick than only those item which is approved they need to post rest of item remain there,
For example:
item1 Des1 approved
item2 des2 not approved
than only first line need to post second line remain there in item journal.
Shailesh
According to the requirement,Add new a Boolean Field like Aproved.
Then Filter Records,which are Aproved(Boolean Field = True).Pass it to the Posting Routine.
Sample Code:
Under POst Menu Item
ItemJournalLine := rec;
ItemJournalLine.setfilter(Approved,’%1’,true);
rec := ItemJournalLine;
CODEUNIT.RUN(CODEUNIT::“Item Jnl.-Post”,Rec);
Hi Shravan,
Thanks for respons It will check all the line or the first line only,
suppose condition line this
example : item1 desc approved
item2 desc not approved
item 3 desc approved .
than this will work or not just clarify this.
Shailesh
Above Code will check the All records which are having Boolean field checked.
Do proper testing before implementing it.
