Because of the difficulty of sorting data with navision, I change to use crystal report to generate the report instead of navision report. I need the coding when I call crystal report from automation server. Any helps would be grateful. vjet
Hi vjet, there should be a helpfile on your CR-cd or in your Seagate-Directory on the harddisk which explains how to use the Automation-Server. There are Examples in C++ and VB. The VB-examples are really helpfull. And there is a list of Methods and Objects you can use. I don’t know the exact name of the file, sorry. If you can’t find it, leave a note here and i will see if i can find it anywhere. Also there should be a little book delivered with your cd, which gives some examples in VB. Hope this helps. Greetings, Frank
