How to Reverse Posted Picking List
I have a query.
My user post picking list of 3 lines. now user want to reverse 1 line (1 item) from it and put it back to inventory.
There are no production order linked to it.
any suggestions?
Thanks in advance.
Ramesh
You can use the unpick function on teh line of the completed picking list registration. You did not say your version but pretty sure it is in AX2012 and AX2009.
Sorry…ITs 4.0 SP1.
still the solution you suggested remain same?
Cannot remember that far back - just look at the option on teh posted registered pick line!
I have not found any option “unpick” function…can u pls give the path in Ver 5.0 (Ax 2009)
We are managing the same using Reset of that Production Order …whatever journals we posted, if we reset the production order, it will get reversed.
RK
You did not mention it was production picking list. With this you can go to the picking list journal and create a new one, on the header you have a picking list button and create lines, in the prompt in the proposal field set it to “Full Reversal” and then post it.
