I am Trying to revalue the Item Negative Adjustment. The Cost is not getting adjusted with the Positive adjustment after running Costing “Adjust Cost-Entries”.r
On Revaluing the Neagtive Adjustment i am getting error "Positive must be Yes in Item Ledger Entry Entry No.=‘12222’
Yes, actually i have passed a Positive entry with Quantity as “65500” but due to wrong date involved i passed a negative adjustment for the same.
And in am trying to revalue that Negative adjustment with Cost 0 but i am unable to do so as system is not allowing. The Positive entry got revalued well but i am getting problem in Revaluation of negative entry as that have not get adjusted on running Cost Patch of System
Actually when i passed the positive Adjustment for Item Opening then i revalued the Positive Adjustment to 0 Cost for correction and i run the Cost Patch in System but due to some date mistake that Positive adjustment was wrong so i passed Negative to correct and i run patch and system on patch running system doesnot adjusted the cost of negative adjustment
I have already passed the positive and negative of Quantity 65500. Then of how much quantity i suppose to pass to adjust the cost of negative adjustment.
