hello everybody.
i’m trying to retrieve the Sheets Names of an excel workbook. i’ve tried lots of things but nothing is working and i cant find a post here that answers me.
there’re multiple sheets and i want to store them in a table in Nav
so any suggestions ?
Thank You.
OK. Finally I got it after several and several of tries
and here’s the Code:
Variables:
ObjExcel Automation ‘Microsoft Excel 12.0 Object Library’.Application
ObjWorkBook Automation ‘Microsoft Excel 12.0 Object Library’.Workbook
ObjWorkSheet Automation ‘Microsoft Excel 12.0 Object Library’.Worksheet
Code:
IF ISCLEAR(ObjExcel) THEN CREATE(ObjExcel);
ObjExcel.Visible(TRUE);
FilePath := Wind.OpenFile(‘Import File’,’’,2,’’,0);
ObjWorkBook := ObjExcel.Workbooks.Open(FilePath);
ObjWorkBook := ObjExcel.ActiveWorkbook;
FOR i := 1 TO ObjWorkBook.Worksheets.Count DO BEGIN //Get All Sheets Names
ObjWorkSheet := ObjWorkBook.Worksheets.Item(i);
SheetsNames[i] := ObjWorkSheet.Name;
END;
// Now you have sheet names in SheetsNames Array
CLEAR(ObjExcel);
Hi! This is good. I have a very close problem and my approach is similar to yours. I am trying to update a complex spreadsheet, with macros and rules. I need to be able to obtain a sheet, and move to specific cells to dump data. I can easily do it when I create my own sheet, but problem is picking and getting control of a sheet in a file. So far, I have added navigation options to the report and am able to navigate and select a file on the drive, and also select a sheet in the file, but that is about it. Attempt to update throws this error:
This automation variable has not been instantiated. You can instantiate it by either creating or assigning it.
What am I missing?
Robert
