stan
June 21, 2007, 7:20pm
1
i made report label by wizard
it could be 3 columns or more (horizontally)
but i want to repeat 3 more (Vertically)
for example
Item A Item B Item C
I want to be
how could i create syntax for this?
kriki
June 21, 2007, 10:46pm
2
In case they are labels with other information, no need to do it, when printing, Navision takes care of it.
In case they are labels with THE SAME information as the ones on the first row, just copy them.
stan
June 22, 2007, 12:14am
3
hmmmmm first i had an idea like you do…
but this is uncomfortable i think
because if we want to change 1 column, then we must do it severally
i though anyone of you could give me a clue how to loop the label
kriki
June 22, 2007, 2:09am
4
What do you mean with “how to loop the label”?
Navision is already doing that. It reads the records and once the 3 labels of a section are filled up, it prints the section and then continues reading records.
stan
June 22, 2007, 3:26am
5
nope…
i mean i want looping vertically
so if i have item A, B, C
it will be
kriki
June 22, 2007, 6:26am
6
So, on the 3 rows, each Item A is the same item?
In that case, the easiest way is to copy the the controls.
