I want to delete the department access form the few user can any one has an idea how to deactivate the department or how to remove it form user window.
Check this post
Thanks Mohan
I have gone through it but , not find any solution.
shailesh
Can you tell us what didn’t understand in the link?
Means here not define how remove it or disable it.
So now you have to start the client with the -config and -profile startup parameters…
Then once into the client you can select “Customize Navigation Pane”. And you you click Departments and Remove. That’s it!
After this then the user cannot reinsert the departments menu. He will only be able to see the items available in his navigation pane. He cannot use search to find anything else either.
Didn’t you see above comments in Erik’s post?
Shailesh,
I think you need to read it carefully and try it
