I have the form with one grid and one button
in that grid contains four field when i press the button the field values will be update by coding in button cliked event.
the upadation is work but grid is not refreshed?
Could U help me Plsssssssssssss???[W]
Hello,
After you are updating the record you need to write
Datasource_ds.reread();
Datasource_ds.refresh();
or
Datasource_ds.research(true);
Regards
Arun Garg
Thanks Arun its working
but i tried this its not working
can u pls tell me what is different between research and reread and refresh
At the end of clicked method just write as:
Table_ds.research();
Table_ds.refresh();
Go here for the difference: http://kashperuk.blogspot.in/2010/03/tutorial-reread-refresh-research.html
Thanks for all its working
Im a beginner please always help me like this… Thank u
