stan
April 16, 2008, 10:37am
1
hai all… i have subform that bound to a table
but at the header it is a unbound form
so if i gave the parameter in DocumentNo at the header
it should be appear in the subform all records that same with the documentNo
the code is right, but i should refresh it manually (by pressing CTRL + ALT + F5)
CekStokBOM.RESET;
CekStokBOM.SETRANGE(“Document No.”,DocumentNo);
CurrForm.SubFormCekStok.FORM.SETTABLEVIEW(CekStokBOM);
what code should I add, if I want to refresh it automatically?
thanks
IMRAN
April 16, 2008, 10:47am
2
What i understood , you want to update the subform. What you can do is to create a function e.g; XX, without any parameters or any return value. Under this function XX, write code CurrForm.UPDATE. So your next line will be CurrForm.SubFormCekStok.FORM.XX;
Is this what you want?
stan
April 16, 2008, 11:00am
3
where we should add that code?
form from subform?
or form header?
i already make functions like you told me at form header…
but it couldn’t , it was said that i must create C/AL global for XX
IMRAN
April 16, 2008, 11:46am
4
it should be form header. the function XX will be in the subform. and call this funtion from the form header. Like the way i told you.
stan
April 16, 2008, 11:52am
5
exactly !!! this is what i want
thanks a lot IMRAN
