I am writing a Read method in VS2008 .But it doesn’t read the Ax data and also it display result is nothing…My code is like this…!
any mistake in this…? plz reply Quickly…
public string ReadData()
// Create the .NET Business Connector objects.
Axapta ax;
AxaptaRecord axRecord;
string tableName = “EmplTable”;
// The LogisticsAddressState field names for calls to
// the AxRecord.get_field method.
string strNameField = “EmplId”;
string strStateIdField = “Dimension”;
// The output variables for calls to the
// AxRecord.get_Field method.
object fieldName, fieldStateId;
try
// Login to Microsoft Dynamics AX.
ax = new Axapta();
ax.Logon(null, null, null, null);
// Create a query using the AxaptaRecord class
// for the StateAddress table.
using (axRecord = ax.CreateAxaptaRecord(tableName))
// Execute the query on the table.
axRecord.ExecuteStmt(“select * from %1”);
// Create output with a title and column headings
// for the returned records.
Console.WriteLine(“List of selected records from {0}”, tableName);
Console.WriteLine("{0}\t{1}", strNameField, strStateIdField);
// Loop through the set of retrieved records.
while (axRecord.Found)
// Retrieve the record data for the specified fields.
fieldName = axRecord.get_Field(strNameField);
fieldStateId = axRecord.get_Field(strStateIdField);
// Display the retrieved data.
Console.WriteLine(fieldName + “\t” + fieldStateId);
// Advance to the next row.
axRecord.Next();
// Keep the console window open.
System.Console.WriteLine(“Press any key to exit.”);
System.Console.ReadKey();
catch (Exception e)
Console.WriteLine(“Error encountered: {0}”, e.Message);
// Take other error action as needed.
return “Record Reded” ;
Pavan.
