Mine problem is that i m using two tables in one report. In fetch method i m sending one table. and another is being used for displaying data. But in range i needed both the tables field but able to add only one table field whom i m using in fetch, how to add other table field in range is my problem if anyone can please solve my problem
Why don’t u simply add in the report query, under the second datasource, ranges node the field u need?
