I have a SSRS report with a table. How can I get gridlines to print on this report?
Bob
Bob
you can create you own ’ Table Style Template ’ and set the border style property as you required eg. Solid.
after creating TableStyleTemplate you can assign TableStyleTemplate to Report which you want.
if you are using AutoDesign then follow the below steps.
select Report–>Design–>AutoDesign–>DataSetName
Select DataSetName right click select StyleTemplate property assign TableStyleTemplate which you have created.
hope it will help you.
