While publishing app I’m getting this error, Please help me out for publishing business central App
Are you the customer or partner?
For field HideDetails you need to set Application area = …
it is from MS Docs (docs.microsoft.com/…/applicationarea-property):
An application area tag must have the format #name, where name is the application area. The name can be any combination of letters (Aa-Zz) and numbers (0-9) without spaces. For example, to specify the Basic and Fixed Assets application areas, set the property to #Basic,#FixedAssets.
If the control applies to all application areas, you can set the property to #All.
Permission Set for table - docs.microsoft.com/…/how-to–create-or-modify-permission-sets + github.com/…/1880
