Getting label name from one of created table “Lablename” and printer the labelname in printer using X++ code.
Can you please add more details? May be explain with an example.
I have a table which contains three fields.one field is printer path and another one is label name,label name come from enum. want to print this label name in mentioned printer path in ax 2012.
How to print the table data in Ax 2012.Is any sample code to print data to printer.
See if you can follow this,
technet.microsoft.com/…/hh597174.aspx
want a X++ code to printer for table data which is used in classes.
I meant to follow the similar approach.
