How to print the blank Purchase Order or Sales Order
I need to print out the blank Purchase Order form but when need to print out the form, they will ask the characteristic to input the data so that the can generate the report through out using the input data to get the output of the printing.
But what is asking to is that i need the blank form as the reference so that we can know which can put the information and which not…
Kevin
So you need to print a blank Purchase Order report?
Hi Mohana,
Not only the report and also need the form print out so that i can compare both of this material
Kevin
Did you check File–>Send–>Form to Microsoft Word or Microsoft Excel options?
Are you able to print blank report?
Hi Mohana
yes, for that one i able to convert the form or the report to do the blank form but the alignment is still having the problem when do transfer from the system to Microsoft office.
But what i want is from system itself to print the blank form, isn’t possible?
thanks
kevin
I think No…
You can compare directly from Form also…
The form and report will get values from table and print…
why do you want to compare again?
Hi Mohana,
which mean we only can do the blank through microsoft office, we cannt done it in system itself?
Kevin
Yes, as per me we cannot [:(]
so, the solution need to be export out to microsoft office as doing the blank form, isn right mohana?
Yes, you can press F3 (New) and send to excel
ok mohana…understood…
thanks
