We use Navision 5 SP 1. When we view the item ledger entries the sort defaults to the first sort option in the list. We always have to change it to the sort order we want to use. Is there a way to permanently change the default sort ?
Go to the Item Ledger Entries form.
Tools->Designer
View->Properties
You can use the assist edit to change “SourceTableView” property.
or if you are fine with the sirt but want to change where the form starts then change the
“SourceTablePlacement” property to either (First, Last, Record or saved) you can click on F1 while on that field to see what each option does.
Thank you. This works great!
