how to pause the data in jobs
static void sendMsgToOnlineUsers(Args _args)
Eventinbox msgbox;
EventinboxId msgboxId;
SysClientSessions clientsessions1;
while select clientsessions1 where clientsessions1.Status == sessionstate::Running
msgboxId = Eventinbox::nextEventId();
msgbox.initValue();
msgbox.ShowPopup = NoYes::Yes;
msgbox.Subject = “Message d’alerte”;
msgbox.Message = “Message de test de l’application AX2009”;
msgbox.SendEmail = false;
msgbox.UserId = clientsessions1.userId;
msgbox.InboxId = msgboxId;
msgbox.AlertCreatedDateTime = DateTimeUtil::getSystemDateTime();
msgbox.insert();
no errors but i want infolg
Count count1; //declaring a count variable
while… // increment the Count in loop
//your code…
count1++;
info(strfmt(’%1’,count1)); // getting the info
it may be helps you…:slight_smile:
Not sure what do you mean by that. Please make sure your queries will make sense to others [:)]
