How to move cursor to new line after reading a barcode?
I have tried few posts, but they didn’t help me…
I am using ax 2009
I am using ax 2009
Hi Chiranjeevi,
work with the below code it may help you
Array tabOrder = new Array(Types::Integer);
super();
tabOrder.value(1, Test_onhand_Item.id());
element.tabOrder(tabOrder);
Test_onhand_Item.setFocus();
Thank you sravan,
I have added this code in gotFocus method and the it is working fine now.
and Thank you Kranthi for your valuable suggestion.
I have also added below code along with gotfocus.
Test_onhand1.clear();
Test_onhand1.Item = “”;
Test_onhand1.insert();
Test_onhand_ds.research();
Test_onhand_ds.findRecord(Test_onhand);
in the modified field of the itemid which is read through the barcode.
