If the company want to do the stock opname activities someday ( such as the end of the month or the end of the fiscal periodic or the end of the year ), how do they do that ? Of course the first step is print the list of all the inventory ( what’s the name of that report in Navision Financial ? ) And after that input the result of the stock opname activities into the Navision Financial system ( does the menu called Phys. Inventory Journals ? ) And then … what the next step ? Anyone can help me please ? Thanks for the cooporation Best Regards, Agatha Agatha
Hi Agatha, What is “stock opname”? Valentin Gvozdev BMI Inc.
Thanks Agatha, Now I know what do you mean. We use term physical inventory for this activity. You need to run function calculate inventory from Phys. Inventory Journal. It will generate Inventory status as of today. Then you should print “Physical Inventory Count” report. A lot of clients ask us print special physical count cards. When you count inventory you should fill field “Qty. (Phys. Inventory)” with real counted quantity. System will post negative and positive adjustments to make system inventory equal counted inventory. Valentin Gvozdev BMI Inc.
