Null value is possible for a dimension. All you need to do is in the COA config, click on the filter. Another form will open where we define dimension values. There is a option of selecting Allow blank. Check that. Activate the COA config. Your purpose will be solved.
Hello Pranav I am using AX 2012 and I don’t see filter in the Configure Chart of Accounts form or COA form. But I see 'Advanced Rule", Account alias etec., Could you please tell me where it is
Select the required configuration which contains the ledger for which null values has to be enabled and click on Edit.
On the config form, we define main account and dimension combination For example we can have main account and active dimensions as Department and Purpose.
Not its required that Department dimension can be null. There is a filter icon on dimensions. Click on that.
Another form will open where we specify dimension values. There is a check box for allow null.
Place check mark on allow null. Close the form and re-activate configuration.
System will now accept blank department for the account in the config.
Ameen, you need to stop entering questions on posts that are marked as complete - people do not generally read resolved calls. Although related you should post a new post then you will not keep trying to bump your additional questions back up to the top of the active topics, this way you will be less frustrated and may get your answers quicker. Chances are you will not read this fulfilling my own prophecy [:D]
