C/FRONT (1,800)
Platform This granule allows you to use the C programming language to make an external program function as a client of a Microsoft Dynamics NAV database.
C/FRONT is a programming interface (API) for the Microsoft Dynamics NAV database.
Among other things, C/FRONT allows you to integrate Microsoft Dynamics NAV with an electronic mail system. The granule can be used with specific solutions developed for Microsoft Dynamics NAV.
For each instance of C/FRONT use, one additional session is required.
This is a quote from Pricelist explanation doc regarding granule 1800.
All Designers allow you to create/modify respective objects - for example, 7110 allows Reports/Dataports, including C/AL IN THEM ONLY.
Application Builder (7,200) and Solution Developer (7,300) can be bought by Customer for almost full development access, but they are VERY expensive.
Finally, Partner (developer) license includes numerous other Granules, not available to Customer - these allow full access to all objects, and also usage of special development & upgrade tools.
BTW, do you work for Partner or for Customer? If Partner - all this info should be available to you in details, I draw only general idea hereā¦
You do not have a developers license as you described it. You will need the Application Developer and Solution Developer granules for that. Last I saw they were almost $30,000 in the US.
