How to know what version of hotfix is installed?
There are few hotfises available now. And we have installed some. But how and where can I check what version of hotfix is installed?
Hi, You can check in the Vesrion List in Object Designer.
Hi, Rajesh, The version list likes this “NAVW13.00,NAVSG3.10.01”. How to tell which hotfix? Thanks.
In your example the codes mean: NAVW13.00: Worldwide Version has been changed last time for version 3.00 NAVSG3.10.01: The local Singapore version has been changed last time for version 3.10, ServicePack 1 That means, this object has been included in ServicePack 1 for Singapore-version 3.10. Of course other objects in the database can have newer versions.
thanks, all!
To continue this: NAVW13.10.01.05: Worldwide version with hotfix 5 Also remember that the hotfixes not always includes objects, so you can’t check the version just from the objects, sometimes you actually have to check the date of your executables.
Hi, I proposed include HotFix number in C1 in function Application version. Then we can see all information in Help>About. Answer was - we don’t need that.
Hi. To find out about the version of the executables use Help and About. The first line shows the Version e.g. “Version W1 3.70 (3.70)”. Double Click on the line and the Build pops up e.g. “Build 13643” Regards, Steen
What does the buildno mean?
