How to know the databaseserver name and databaseserver instance in navision?
hii,
not sure which version are you using.
Did you check GetDatabaseIndicatorText function in table 79
i am using nav 2016
From Development Environment Press
ALT + F + B + I
no i want the value of databas server name and database server instance in variable through coding.have you know any function regarding this?
If I’m not wrong there is no standard function in NAV to get the value of database server name and database server instance; please refer this link; kauffmann.nl/…/
Working on it… Have found a solution. Will be on my blog very soon.
kauffmann.nl/…/
Give it a try, for me it works without any errors. No warranties of course, this is way beyond normal documented features.
