how to insert multiple values from temporary table to my main table
Hai To all ,
i have one temporary table in that i create field in header ( cust account , invoice account , purch id, sales name,sales id ) and in lines ( item number , qty , unit price , proj id ) from here i want to insert values to my main table (sales order) …
here i create class and write coding for insert values from temporary table to my main table ( sales order)…
now i want to insert multiple values from temporary table to my main table ( sales order) … what can i do for that ???
while select HeaderTable
NumberSeq = NumberSeq::newGetNumFromCode(SalesParameters::numRefSalesId().numberSequence);
sid=NumberSeq.num();
salesTable.SalesId = sid;
salesTable.initValue();
salesTable.CustAccount = HeaderTable.CustAccount;
salesTable.InvoiceAccount = HeaderTable.InvoiceAccount;
salesTable.CurrencyCode = ‘USD’;
salesTable.initFromCustTable();
salesTable.insert();
salesTable.clear();
while select LineTable
sl.SalesId=sid;
sl.ItemId = LineTable.ItemId;
sl.CreateLine(NoYes::Yes,NoYes::Yes,NoYes::Yes,NoYes::Yes,NoYes::Yes,NoYes::Yes);
info(“Sales Order Created with Line”);
fl=SalesFormLetter::construct(DocumentStatus::Invoice);
fl.update(SalesTable::find(sid));
info(“Sales Order Posted”);
hai every one for creating temporary table and insert values to main table ( sales order)
here i use codes in class are given here
public class TmpSalesOrder
SalesTable salesTable;
SalesLine salesLine;
HeaderTable headerTable;
LineTable lineTable;
NumberSeq NumberSeq;
SalesId sid;
SalesLine sl;
SalesFormLetter fl;
TmpSalesOrder tmpSalesOrder;
int counter;
Public void create(SalesTable _salesTable)
ttsbegin;
while select forupdate headerTable where HeaderTable.CustAccount == _salesTable.CustAccount
HeaderTable.Creation=“yes”;
HeaderTable.ErrorStatus=StatusOfErrors::No;
HeaderTable.ErrorMessage= “Sucess”;
HeaderTable.update();
ttscommit;
public void errorDetails(SalesTable _salesTable)
ttsbegin;
headerTable.ErrorStatus=StatusOfErrors::Yes;
headerTable.Creation = “No”;
headerTable.ErrorMessage = " values are not inserted ";
headerTable.update();
ttscommit;
public void insertGateLines()
ttsbegin;
salesTable.clear();
while select lineTable where lineTable.SalesId == headerTable.PurchId
if(InventTable::find( lineTable.ItemId ))
//sl.clear();
sl.SalesId=sid;
sl.createLine(true, true, true, true, true, true);
tmpSalesOrder = new TmpSalesOrder();
tmpSalesOrder.create(SalesTable);
else
tmpSalesOrder.errorDetails(salesTable);
Info(“Sucess”);
ttscommit;
public static TmpSalesOrder construct()
return new TmpSalesOrder();
static void main(Args args)
TmpSalesOrder TmpSalesOrder;
TmpSalesOrder = new TmpSalesOrder();
TmpSalesOrder.insertGateLines();
i create a temporary table for insert values and create a button for pass values from tmp table to main table ( sales order)
with the following code using in class … i use this fields for insert values in my tmp table and the help of copylines button i pass the values to main table ( sales order) …
