hello all,
i want get data from web tracking (status) insert into NAV , i have API key for connection but i not know about used JSON and REST in NAV for get data
Please help me
kind regards,
NKE
hello all,
Please help me
kind regards,
NKE
My car wont start! What could be wrong???
Because you didn’t provide ANY information at all… all we can do is give you this link (which took 2 seconds to google).
docs.microsoft.com/…/web-services
So If you want more help then allways remember to include more information!!!
2 What build No.?
What table(s) do you want to integrate with
is it behind a firewall?
2 What build No.?
Sales Shipment Header , i will add field Status
No
Start with the link that you got above - it will give you the necessary information. These are the steps though:
Create a New Page containing the necessary fields (The primary key, the fields that you want to see and or Update. - Make sure that the page is editable - Delete Allowed No, Insert Allowed No.
Publish the page in web-services
Use the link that is being generated
If you have to use the webservice from “outside” then you have to open your firewall to allow access, and you ABSOLUTE MUST create a proxyserver with userid and password.
If you don’t know why and how, then find someone with the necessary skills.
i want data form web AfterShip.com
Ohh, see - you did not provide any information - and now its not FROM Dynamics NAV but TO !!!
Take a look at:
http://www.dynamics.is/?p=2637
Besides from that: why use aftership.com? Does the shipment company not have their own api? (It site you are linking to is not cheap).
yes,company not have their own api . used web tracking service , because tracking no. be logistics providers
That should not be to hard to do - It will probaly take a day or so to code.
Have fun
If you ask an experienced NAV developer to do it! If you have no or limited previous NAV development experienced, then expect it to take 2-3 weeks…
Well I would not say that this is a task for a non experienced developer - but yes, at least a week or two would a junior developer spend on the job - but only because the example provided above gives a pretty good hint on how to code it.
I not understand example. please help me create code pull data from AfterShip ?
In short NO… The Example works perfectly, and it can directly be changed into Aftership if you understand the code.
If you where a customer I would charge you around 2500-3000 EUR for creating the code, and spend a day or two on it.
So you either have to decline the task from your customer, or get a more experienced colleague at your office to help you.
Besides, you have not spent many hours with the example before you wrote “I not understand example”. Erik wrote that a non-experienced user would probably spend 2-3 weeks…You should start spending that time and don’t give up.
If the customer don’t want to pay that much. Find someone among your colleagues that can do it faster.
Thanks for the good advice.
