I have a question where i already created a new report to show the number of sales order invoices and the amount,
but the issues is that i able to total up the amount quantity of each Sales Order invoice but only i cannot able to do it how to
indicate the number of Sales Order invoice .
For example
Sales Order Quantity
SO-xx-xxxxx 20
SO-yy-yyyy 15
2 35
I was able to do the total for quantity but for sales order , i cannot able to do it…
Any way help me and advise how to do it…
kranthi
September 29, 2011, 3:27pm
2
Declare a global integer variable in the report(class declaration). And increment it when ever you are executing body/programmable section. Display it according to your requirement.
Hi kranthi,
Can you verify more on that information. because i still don’t know how to make it…
can you guide me…
kevin
Hi there,
Any want can help me…
Please i need the guide to do so…
Kevin
Declare a variable in Class declaration of the report like - int noOfSo;
Override the execute section method of the body if you are using a body to print the sales order and increment the integer - noOfSo++;
Then print that int variable in footer/programmable section(according to your report design) by adding display method.
