How to import items into released products from excel
How can i import items into released products in Dynamics AX 2012?
The Data Import Export Framework (DIXF) can automatically release import products to companies specified in ReleaseProductCompany field (of the Product entity). DIXF supports Excel.
what are the tables required?
You can look at the definition of the entity, nevertheless the whole purpose of data entities is to remove the burden of dealing with individual tables.
you can refer the class “DMFInventTableEntity” and its corresponding query and staging table.
If you have any help file, please forward it.
Santhosh,
Create a processing group and use the standard entity . Since yours is in excel format, use the source data format as Excel. Generate a sample file by clicking “Generate SourceFile” button. You can use this as your sample file.
