Is there a way to prevent my batch job from showing in the history if there was no log? I have a job running every 3 minutes and it uses a query object…if the query object returns no results, it still shows up in the history.
It is difficult to see the information I really want.
This is good info. From this I was able to see that there really is no way to do it without adding a decent amount of custom code. For those curious, the log is stored in a container called “Info”. If I try to change the where clause that inserts the history records to only insert records that have a “log”, AX doesn’t let you put containers in where clauses, so I would have to have some sort of flag that gets flipped, etc.
