Hi guys,
I want to do a cycle for each enum value,some function that will scroll the value of the variable?
something like this:
while(nextEnumValue(enumType))
thanks
Hi guys,
thanks
Could you elaborate ?
How about this:
i = 0;
While( i < enumCnt(enumType))
I want to use the value of the enum (A,B,C) in a select statment
while (nextEnumValue(enumType))
select myTable
where myTable.enumType == enumType; (in the first cycle the value is A, then B, and the last C)
info(strFmt("%1",myTable.enumType));
Use DictEnum.index2value(). You’ll find an example right in the documentation.
thank you Martin Dráb
I was already using this form, but wanted to know if there was a simpler function.
