I have folder in my system [name is Marshal] at following location c:\Marshal.Inside the folder [Marshal] i have 4 files[File1,File2,File3,File4].is it possible to get the name of the files by CAL code if so how to do this.
above code will have the File Name in Attachment2 variable.
Edit: This will not meet your requirement exactly to find about the name of all files in a folder, but if you want to store/ save the name of a file using common dialogue management then above will do that.
I think you want to use the virtual table File. This table will be empty initially, but as soon as you set a filter on the Path field - for example c:\ - the table shows all files and directories in this directory.
To have a quick look you can create a form on the File table and apply a filter (see screen shot).
Thanks for your quick reply.My exact requirment is a folder will have lot of text files i have to import it into a custom table.in single click all the files have to imported into the custom table.the user shouldnotselect any file to import every thing should be automatic.How to do this
