How to get tax amount for LedgerJournalTrans lines
i need tax amount for linewise for reporting purpose
need to get tax amount for non-posted lines in LedgerJournalTrans
Accounts Payable → Journals → Invoice → Invoice Journals → Lines
for both debit and credit i need tax amount
how to get it, any job is there…
Thanks…
Have a look at \Classes\LedgerJournalEngine\taxAmountJournal
I run it through job, while debugging the return value CalculatedTax is 0
while select ledgerJournalTrans
where ledgerJournalTrans.JournalNum == “ABC”
&& ledgerJournalTrans.Voucher == “ABC001”
&& ledgerJournalTrans.TransDate == today()
engine.taxAmountJournal(ledgerJournalTrans);
You are just looping the the records and calculating the tax. You are not assigning the value returned by engine.taxAmountJournal(ledgerJournalTrans); to any variable.
Example = calculatedTax += engine.taxAmountJournal(ledgerJournalTrans);
Thanks kranthi, i acheived my result in otherway
I’m inserting my values in tmpTable and extract the tmpTable i get my values…
Here we using LedgerJournalAccountMovementDP class
  1. before lines executing(b4 while loop for lines starting execution):
where ledgerJournalTrans.JournalNum == ledgerJournalTable.JournalNum
this.calcTaxDocument(ledgerJournalTrans.JournalNum, ledgerJournalTrans.Voucher);
  1. Create Method in class:
protected void calcTaxDocument(LedgerJournalId _journalNum, Voucher _voucher)
TaxEngineLedgerJournalTransHeader taxEngineLedgerJournalTrans;
ITaxDocument taxDocument;
ITaxDocumentComponentLineEnumerator componentLineEnumerator;
ITaxDocumentComponentLine componentLineObject;
ITaxDocumentMeasureEnumerator measureEnumerator;
ITaxDocumentLine line;
ITaxDocumentLineEnumerator lineEnumerator;
TaxAmount taxAmount,taxValue;
TaxComponent_IN taxComponent;
taxEngineLedgerJournalTrans = TaxEngineLedgerJournalTransHeader::findByJourNumVoucher(_journalNum, _voucher);
taxDocument = TaxBusinessService::getTaxDocumentBySource(taxEngineLedgerJournalTrans.TableId, taxEngineLedgerJournalTrans.RecId);
if(taxDocument != null)
componentLineEnumerator = taxDocument.componentLines();
lineEnumerator = taxDocument.lines();
if (taxDocument)
while(lineEnumerator.moveNext())
line = lineEnumerator.current();
line.setTaxDocument(taxDocument);
if(line.originSourceRecId() != 0 && line.getInvoiceTax().value() != 0)
while(componentLineEnumerator.moveNext())
componentLineObject = componentLineEnumerator.current();
taxComponent = componentLineObject.metaData().taxComponent();
tmpFrmVirtual.initValue();
tmpFrmVirtual.RefRecId = line.originSourceRecId();
tmpFrmVirtual.JournalNum = taxComponent;
tmpFrmVirtual._Real2 = componentLineObject.getMeasure(“Tax Amount”).value().value();
tmpFrmVirtual.insert();
if (taxComponent == “SGST” || taxComponent == “IGST”)
break;
  1. used to extract the values (create inside while loop executes where you want):
while select tmpFrmVirtual
where tmpFrmVirtual.RefRecId == ledgerJournalAccountMovementTmp.RefRecId
switch (tmpFrmVirtual.JournalNum)
case “CGST” :
ledgerJournalAccountMovementTmp.CGSTAmount = tmpFrmVirtual._Real2;
break;
case “SGST” :
ledgerJournalAccountMovementTmp.SGSTAmount = tmpFrmVirtual._Real2;
break;
case “IGST” :
ledgerJournalAccountMovementTmp.IGSTAmount = tmpFrmVirtual._Real2;
break;
