Hi guys,
I’am create query to get the settlement the mark check only in AX.
here’s the screen shots.
and also i already create the query(but not yet done).
select b.VOUCHER, b.TXT, b.BANKCHEQUENUM, * from LEDGERJOURNALTABLE a
inner join LEDGERJOURNALTRANS b on a.JOURNALNUM = b.JOURNALNUM
inner join VENDTRANS c on b.VENDTRANSID = c.RECID
inner join VENDTRANSOPEN d on c.ACCOUNTNUM = d.ACCOUNTNUM and c.RECID = d.REFRECID
can anyone help me on this?
how can i query only the mark check(settlement)
Thank you in advance
Hi John,
Its an edit method, you can see the check box MarkTrans checked at backend and you can add condition for it.
Whenever you mark the invoice against paymentjournal(LedgerjournalTrans), One new record will be created in spectrans table.
LedgerJournalTrans ledgerjournaltrans = LedgerJournalTrans::findLedgerJournalId(‘Voucher’);
SpecTrans spectrans;
VendTransOpen vendtransopen;
VendTrans vendtrans;
while select spectrans
join vendtransopen
join vendtrans
where spectrans.SpecCompany == ledgerjournaltrans.DataAreaId &&
spectrans.SpecTableId == ledgerjournaltrans.TableId &&
spectrans.SpecRecId == ledgerjournaltrans.RecId &&
spectrans.RefCompany == vendtransopen.DataAreaId &&
spectrans.RefTableId == vendtransopen.TableId &&
spectrans.RefRecId == vendtransopen.RecId &&
vendtransopen.RefRecId == vendtrans.RecId &&
vendtransopen.AccountNum == vendtrans.AccountNum
info(strFmt(’%1’, vendtrans.Invoice));
Invoice is marked If you are able to find the record in spectrans table.
