I’m trying to get a Journal id using maximum of posted date and time, may i know the coding to do that
select maxof(Posteddatetime) from pjt where pjt.ProdId == “IM039174” && pjt.JournalType == ProdJournalType::RouteCard && pjt.Posted==noyes::Yes;
I tried this but it not showing the record
Check if the query returns anything without maxof(PostedDateTime) . If not, your system doesn’t contain any record fulfilling your conditions.
Yes when giving without maxof the query is showing correctly but when i give maxof record is returning empty
I think you have wrong expectations. Your code will return a value only in PostedDateTime field, all other fields will be empty. This is the correct behavior, but maybe you want something else and therefore you need different code.
kranthi
August 14, 2018, 10:21am
#6
select firstonly JournalId from pjt
order by Posteddatetime desc
Yes i need the last posted record for prod route, how could i fetch that?
Order records by PostedDateTime in descending order and select the first one. That’s what Kranthi meant by his reply.
For example:
select firstOnly pjt
order by PostedDateTime desc
where ...;
Update: Oh, I didn’t notice that Kranthi’s already answered that in another branch of this discussion.
I need to find like this, kranthi.
Based on route I need to find the journal id which was posted at last
If last operation is not posted need to check the before operations
kranthi
August 16, 2018, 8:06am
#10
OK. What issue do you have now?
What does this mean?
I’m not getting the last posted operation, kranthi
like above shown image
120 oprnum isnot posted but 110 is posted i need to get that…
may i have a sample code?
kranthi
August 16, 2018, 11:22am
#12
What data do you see in ProdJournalRoute table for that particular journal id? Have you tried finding the last operation from ProdJournalRoute table?
