How To Filter The one Lookup Value Based on another Lookup in X++ ?
How to get , if I select Vendor Group 10, in below control Vendor account dropdown the corresponding Accounts only to show
any one know the logic
Hope you are doing it in form.
Override the lookup method of that control and use SysTableLookup with vendTable, build the query and apply range on vendGroup and pass the selected vend group
Example: \Data Dictionary\Tables\InventTable\Methods\lookupItemType
Iam Not Getting , can you tell me any form for similar requirement
\Forms\SalesTable\Data Sources\SalesTable\Fields\InventLocationId\Methods\lookup
\Forms\SalesTable\Data Sources\SalesTable\Fields\CurBankAccount_LV\Methods\lookup
This may be helpful to you…
https://community.dynamics.com/ax/f/33/t/162196
http://ssrsax.blogspot.in/2012/05/filtering-drop-down-list-based-on.html
Hii
#sridardax
while writing the lookup method for vendor account box , give the range for that lookup like this
range1 = ds1.addRange(fieldNum(your Table, yourField));
range1.value( firstStringEdit.Value() );
firstStringEdit.Value() → means the value of first TextBox .
